Date/Time: Wed, 12 Mar 2025 22:17:13 +0000
Charts not moving
View Count: 661
[2022-05-26 17:26:11] |
winner - Posts: 4 |
It says I am connected. but charts and Dom not moving. Thanks.
[2022-05-26 17:42:06] |
John - SC Support - Posts: 38621 |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog We will then determine what the problem is. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
