Date/Time: Fri, 11 Sep 2026 06:25:31 +0000
How to set a live data scanner?
View Count: 1584
| [2022-05-26 15:33:42] |
| User840964 - Posts: 75 |
Hello, Is it possible to set in Sierrachart a live data scanner as shown in the attached image, receiving live data from a provider? |
| Attachment Deleted. |
| [2022-05-26 16:50:22] |
| John - SC Support - Posts: 47841 |
Refer to the information for the Quote Board here: Getting Quotes For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-05-27 13:08:41] |
The scanner I mean is self-filling and has filters to select data. I'd like at least to connect a table with my provider platform that has a scanner like that. Is it possible? |
| [2022-05-27 15:24:08] |
| Tony - Posts: 725 |
Are you referring a stock screener where you can set filters? Like the attached 2 screenshots of Yahoo Finance? I don't trade stock, but would be curious to know how to set up a screener in Sierra. Date Time Of Last Edit: 2022-05-27 15:30:54
| [2022-05-27 16:01:28] |
We do not have this.
| [2022-06-06 11:11:34] |
Refer to the functionality Sierra Chart has, for scanning: Study/Chart Alerts And Scanning Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
