Date/Time: Wed, 12 Mar 2025 22:09:28 +0000
Parallel lines config: frozen checkboxes for line extension
View Count: 482
[2022-05-26 15:25:52] |
User840964 - Posts: 49 |
Hello, While it's possible to draw the parallel lines and set their line extensions (forward and back) afterwards, it's not possible to set the line extensions permanently in "Tool Config" since the relevant checkboxes show frozen. If that were fixed is very appreciated. |
[2022-05-26 16:49:25] |
John - SC Support - Posts: 38621 |
If you are wanting to have Parallel Lines that extend forward and back by default, then you need to use the Parallel Rays. You can change the configuration for these to have Extend Back enabled by default (Extend Forward is always enabled, since they are rays).
