Date/Time: Wed, 12 Mar 2025 21:13:33 +0000
Volume text Font change in my VbP study on DOM
View Count: 437
[2022-05-26 15:04:02]
User181801 - Posts: 42
Hello, I cannot find how to change font size in my text that dispays volume in VbP study on the DOM. Could you please help me?
thanks in advance
[2022-05-26 16:15:49]
John - SC Support - Posts: 38621
There are two different text items in the VbP and how you change the size is different for each.
First, if you are referring to the text (typically volume) that is displayed within the bars, then that text size is controlled through a Subgraph. Refer to the information here:
Volume By Price Study: Volume Numbers Text Color and Size (SG7)
If you are referring to the text that is drawn above/below the profile, then that is controlled through the Input for that text. Refer to the following:
https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=141&Name=Volume_by_Price#TextFontSize
