Date/Time: Wed, 12 Mar 2025 21:49:38 +0000
Ray tool - How to snap to one indicator and not another
View Count: 452
[2022-05-26 13:12:50] |
VolTrader73 - Posts: 136 |
Hello. I have multiple indicators in a region 4. Using the pink/magenta Ray tool Id like to snap it the a specific indicator in that region but when I right click the Ray and choose snap to close it chooses an indicator by it self. Second question refers to an alert for when the indicator crosses but If I cant config/choose which one it is then I cant use it. Is there a way to tell it which indicator (in this case to the blue one with the value -32.04 in region 4)? Pls advise Date Time Of Last Edit: 2022-05-26 13:13:08
[2022-05-26 16:01:57] |
John - SC Support - Posts: 38621 |
The Auto-Snap option is going to use the first study that is in the region and ignore any others. You can adjust the studies in the list of studies to graph and put the one to which you want the auto-snap to work with further up on the list than others in that same region.
[2022-05-26 18:10:38] |
That is a problem as the list it self is in a way that one study should calc before another that is based on it. That is far more important. If possible , Please add this feature. Right click the tool and choose which indicator in the region. So no problem with any tool any region, multiple tools in region etc' Would be awesome |
[2022-05-26 21:01:46] |
We have set this as a Feature Request. We do not know when, or if, we will get to any particular feature request. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
