Date/Time: Mon, 05 Oct 2026 08:00:33 +0000
trade positions window and moving SC to new HD
View Count: 658
| [2022-05-26 12:29:07] |
| User386175 - Posts: 31 |
I have 2 questions 1 -- My trade positions window shows data when I am not in a trade. it should only be showing positions that are open. screenshot is attached. how do i fix it 2 -- I added a hard drive to my PC. I need to move Sierra Chart to this new location. How do I do that? Date Time Of Last Edit: 2022-05-26 12:30:02
| [2022-05-26 12:52:41] |
1. That data may be coming from Rithmic. So nothing we could do about that necessarily. When Sierra Chart is not running you could delete the TradePositions.data file in the Sierra Chart installation folder. 2. Refer to: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
