Date/Time: Wed, 12 Mar 2025 22:08:10 +0000
Teton routing and Gain/StoneX
View Count: 591
[2022-05-25 16:39:04] |
User23815 - Posts: 210 |
I am unclear on your latest update concerning Teton and Gain/Stonex. Am I able to leave my accounts at Gain and use the Teton service? In the notice it says (added) next to Gain. But then it also says that you are phasing them out and that newer versions of SC wont be compatible. Just so you know, I am very pleased with SC and have custom studies so I really don't want to leave SC. I also watched the latest video from Stage 5 and SC with the two Anthonys. Stage 5 is my intro broker. I know they recommended Advantage Futures. So my questions: Am I able to stay with Gain? If phasing out do you know when yet? Will Advantage through Stage 5 be fully compatible with SC going forward. Thanks |
[2022-05-25 17:15:36] |
John - SC Support - Posts: 38621 |
The "Added" you are referencing was not about Teton, it was about those services being added to the list of services that will require Package 10 or higher. Gain Capital is not getting any updates from us, so one day it may simply no longer works if they make any changes. And they are not supporting the Teton Order Routing Service. Advantage and Stage 5 are a good combination and look to stay as some of our most active brokers for the Teton Order Routing Service. So we would definitely recommend using them. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-05-27 17:38:13] |
Stage 5 Trading - Posts: 155 |
Hi Trader, As John mentioned, to use Teton Order Routing you will need to move your Stage 5 StoneX account to either Stage 5 Advantage or Stage 5 Dorman. We are here to help walk you through the entire process, so please let us know how we can help and we will make the transition as seamless as possible. I hope that helps. Let us know if you have any questions or we can assist with anything in addition. Thank you and have a nice weekend! Anthony Giacomin Stage 5 Trading Trading derivatives carries a high degree of risk, and may not be suitable for all investors. Past performance is not necessarily indicative of future results. |
