Date/Time: Wed, 12 Mar 2025 20:36:33 +0000
Trade Windows alignment does not work well when switching charts and app size
View Count: 423
[2022-05-25 10:50:06] |
tomas262 - Posts: 148 |
Trade Windows auto-alignment does not work well when switching charts and app window size see the clip attached |
Private File |
[2022-05-25 12:21:36] |
This is not reproducible for us and we think this is a Windows operating system issue. This is the first time anyone has brought this kind of issue to us. This must be an operating system level issue. It is simply not reproducible by us. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-05-25 12:30:00] |
I managed to reproduce even on Windows 7 64 while the previous Win is 2016 server Can you try CTRL + TAB instead of main menu switch? there seems to be a difference... when clicked menu it seems working well while CTRL +TAB messes it |
[2022-05-25 12:32:16] |
What does CTRL + TAB do?
[2022-05-25 12:39:29] |
it switches between charts within a chartbook when maximized ... see the clip attached to see the issue happening only when CTRL + TAB is hit
Private File |
