Date/Time: Thu, 21 Nov 2024 12:50:00 +0000
Chart DOM location on chart
View Count: 748
[2022-05-24 18:34:39] |
Steve Leon - Posts: 301 |
Is it possible to display a Chart DOM on the left hand side of a chart instead of the right hand side ? where/how would you go about doing this ? Thank you Steven Leon |
[2022-05-24 20:44:49] |
John - SC Support - Posts: 36174 |
This is not supported.
[2024-01-17 15:41:45] |
TopGunTrader - Posts: 171 |
I would also like DOM on left hand side OR to be able to remove bid/ask columns as I just like to see the bid/ask pulling stacking column. If its on left hand side can hide most of DOM and just see what I want but for me being able to delete ALL columns I don't want would be great too.
[2024-03-09 06:24:17] |
User547290 - Posts: 58 |
Yes, I have found a need when using multiple monitors to have the DOM on the left side of the chart. That way I can have DOMs next to each other with the charts on the wings.
[2024-11-13 16:55:38] |
User708541 - Posts: 78 |
With all of Sierra's customizability it would be great/amazing if the DOM could be placed on either the right or left side of a chart. Please consider adding this functionality, it would greatly help with multi-monitor setups.
