Date/Time: Tue, 26 Nov 2024 09:45:03 +0000
SC data setup
View Count: 1005
[2014-04-30 15:29:36] |
mattb - Posts: 30 |
any ideas on how to correct the data issue here? Trying to setup SC data. see attached, thanks http://www.sierrachart.com/image.php?l=1398871661533.png Date Time Of Last Edit: 2014-04-30 16:29:59
2014-04-30_1022.png / V - Attached On 2014-04-30 15:24:21 UTC - Size: 56.59 KB - 342 views |
[2014-04-30 16:29:36] |
The Message Log was not needed and has been removed. You have a data error in the chart. Refer to help topic 2.1 here: http://www.sierrachart.com/index.php?l=doc/helpdetails2.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-04-30 19:09:43] |
We now realize what the source of this data error is from. The problem is resolved. Update Sierra Chart by following the instructions here: https://www.sierrachart.com/index.php?l=doc/download.php#FastUpdate Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
