Date/Time: Wed, 12 Mar 2025 20:48:56 +0000
Connect to data feeed : service package does not support this ..
View Count: 359
[2022-05-24 16:45:13] |
User777195 - Posts: 1 |
Hello, since this week I cannot connect to my CQG-Data feed anymonre. On the logon settings window the following is written: CQG WebAPI )not enabled on package) |
[2022-05-24 16:55:59] |
This is resolved. You should be able to connect now. Also refer to: Service Package Changes | Discontinued External Services | Reducing Overall Costs Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-05-24 16:56:05
