Date/Time: Wed, 12 Mar 2025 20:25:39 +0000
Delayed Data
View Count: 566
[2022-05-24 16:04:26] |
User865754 - Posts: 7 |
I am getting a delayed data.
[2022-05-24 16:10:54] |
John - SC Support - Posts: 38618 |
You need to go through the Setup Instructions for the Denali Exchange Data Feed. If you want data for the CME Group, then follow these instructions: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* If you want data for the EUREX, CFE, or NASDAQ TotalView, then follow these instructions: Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-05-24 16:58:46] |
if I trade micos and minis equity futures ES, YM, NQ and RTY would activating "CME with Market Depth for nonprofessional Trading accounts" be enough?
[2022-05-24 18:11:52] |
YM is not traded on the CME Exchange, so if you activated the CME With Market Depth for nonprofessional Trading Accounts, then you would not have the real-time data for YM. YM is traded on the CBOT. Therefore, if you want data for all 4 symbols with Market Depth, then the cheapest option is to activate the following exchanges: - CME with Market Depth for nonprofessional Trading Accounts - CBOT with Market Depth for nonprofessional Trading Accounts If you also want data for the rest of the CME Group, but do not need Market Depth for them, then you would want to add the following: - Full CME Group (CME, CBOT, COMEX, NYMEX) for nonprofessional Trading accounts Also, note that if you want one more of the CME Group exchanges with Market Depth, then it is the same price to get all 4 by activating the following: - Full CME Group (CME, CBOT, COMEX, NYMEX) with Market Depth for nonprofessional Trading accounts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
