Date/Time: Wed, 12 Mar 2025 20:49:56 +0000
Teton - How far back does the NQ Trade History go vs. CQG Data? Seems like less?
View Count: 701
[2022-05-24 15:12:27]
HumblyTrading - Posts: 192
Hello SC Team,
I am gradually shifting to Teton (IronBeam) from CQG (AMP Futures).
However, I have run into an issue.
On CQG, I can have well over 2000 days of history on any intraday chart.
For example, I often will go into the details of what happened on a 100-Trades chart or a 5-minute chart for ES/NQ, however far back in history it was since the last time price was at that level.
This helps me fine-tune my trade levels down to a few tick range.
I noticed that when duplicating my SierraChart folder from CQG (so that every setting is exactly the same), and then switching my Trade Server to Teton, I only get a fraction of the historical data. It does not seem to go back beyond 2021.
Is this a limitation with Teton? Or is there a different setting I need to be aware of?
Thank you for any help!
Mike
[2022-05-24 15:29:50]
John - SC Support - Posts: 38621
The data for the CME Group goes back to 2011 in 1-tick data and back to 2008 in 1 minute increments. Refer to the information here:
Sierra Chart Historical Data Service: What is Included
Refer to the following for how to get more data into a chart:
Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data
[2022-05-24 15:32:53]
Thanks. Does that apply also when using Teton?
[2022-05-24 16:03:35]
Yes. It does not matter what your service is set to, you have the same access to the data.
[2022-05-24 16:34:22]
Thanks. I now see that when I duplicated the SierraChart folder, for some reason, the global setting for max # intraday downloads was defaulted back to 50.
All set now. Thanks again!
Mike
