Date/Time: Tue, 29 Sep 2026 18:59:08 +0000
Manually set DOM update interval
View Count: 1205
| [2022-05-23 21:54:27] |
| User110547 - Posts: 11 |
Hello, is it possible to manually set the DOM update interval, including last price, L1 and L2 updates?
| [2022-05-24 13:31:50] |
| John - SC Support - Posts: 48058 |
There is not a way to do it specifically for the DOM that is part of a Chart. But you can set the Chart Update Interval per chart, including Trading DOMs, which are specialized charts. Refer to the information here: Chart Settings: Chart Update Interval in Milliseconds (Chart >> Chart Settings >> Display >> Chart Update Interval menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-05-25 17:00:25] |
| User409050 - Posts: 22 |
Hi John, does time and sales window have the same update interval as the chart its linked to? or it's a separate chart? |
| [2022-05-25 18:02:43] |
Time and Sales is completely separate and is in real-time.
