Date/Time: Wed, 12 Mar 2025 16:34:57 +0000
chartbook
View Count: 479
[2022-05-23 18:40:16] |
User458314 - Posts: 1 |
I installed a new chartbook. Therefore i closed the example chartbook and opened my new chartbook. Unfortunately when i open sierra chart again the example chartbook appears and not my chartbook. Is that normal or can i install it firmly? |
[2022-05-23 20:06:17] |
John - SC Support - Posts: 38612 |
Refer to the following setting, and the one after it, for how to define which chartbooks open automatically: General Settings Window: Open Files On Startup (Global Settings >> General Settings >> General >> Startup) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
