Date/Time: Wed, 12 Mar 2025 16:45:06 +0000
Documentation refers to Study Subgraphs Difference but it is missing
View Count: 485
[2022-05-23 14:46:38] |
YSS - Posts: 112 |
Hello, I'm trying to follow this documentation part: Add Additional Symbol: Seasonal Spread Analysis It is a bit confusing but I'm following it and I come to the section where it says to add the STUDY SUBGRAPHS DIFFERENCE yet i cannot find it in the list of studies. I am running latest 2394 version The section of this documentation could do a bit of a re-write if you ask me. Please advise. Thanks Date Time Of Last Edit: 2022-05-23 14:48:34
[2022-05-23 15:09:18] |
JohnR - User831573 - Posts: 319 |
Maybe this is what you are looking for. Study Subgraphs Subtract/Difference This study calculates and displays the Difference of two study Subgraphs. Hope this helps, JohnR |
[2022-05-23 16:08:20] |
YSS - Posts: 112 |
I would need more than 2 legs
[2022-05-23 16:49:26] |
John - SC Support - Posts: 38612 |
We recommend using our Custom Calculated Symbols rather than taking the difference between the studies. Refer to the following: Custom Calculated Symbols For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-05-23 17:06:23] |
YSS - Posts: 112 |
The problem is that the Custom Calculated Symbols only work with Intraday charts, which is completely useless for spread traders bascially
[2022-05-23 18:03:22] |
Another option then is to use multiple of the Add Additional Symbol in combination with the Spreadsheet Formula (bar) study. In the Spreadsheet Formula (bar) you can put in multiple items, so if you had 3 total symbols on a chart (1 main and 2 add additional symbols), then you could enter a formula like the following for the Open: =ID0.SG1 - ID1.SG1 - ID2.SG1 You can then also add arithmetic values to these to get what you want. Refer to the following for the Spreadsheet Formula (Bar) study: Spreadsheet Formula For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
