Date/Time: Fri, 14 Mar 2025 10:10:26 +0000
SCROLL THROUGH CHART PROBLEM
View Count: 716
[2022-05-23 07:56:36] |
Mustang77 - Posts: 122 |
Hi Let's say i'm looking at ES or Gold chart, and i scroll back 2 weeks or 3 weeks to see a candle, when i scroll again to current time, the price scale moves up or down and i lose the frame of what i'm looking at. for example, i go to 2 or 3 weeks ago, and i see an imbalance on a candle, i draw a horizontal ray on that price level, now i want to see how the future candles reacted to that line, so i scroll forward to current time but what the chart does is it scales and moves the chart up and down and i lose completely that line. How can i make it FIXED? so when i scroll with the mouse wheel it stays in the same price level ? Thanks in advance |
[2022-05-23 08:23:46] |
Sierra_Chart Engineering - Posts: 18778 |
Refer to: Chart Scale and Scale Adjusting: Using Fixed Values for Top and Bottom of Scale Range Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-06-03 09:04:15] |
Hi Let's i want to see the market profile of 15 days ago, for example on 15 may, and today is the 3 june, instead of scrolling through and/or dragging the chart to the right and losing all the picture along the way, is there a quicker way to just enter the date somewhere of the 15 may and the chart takes me there directly? just like on TradingView for example where you enter a date in the calendar and the chart takes you there. Thanks |
[2022-06-03 09:07:42] |
Also, let's say i scroll through and i'm looking at the chart in a previous date, like 2 months ago, how can i put the chart back to today's date? On TradingView you right click on the chart and click on RESET and it brings the chart back to today Thanks |
[2022-06-03 09:08:01] |
User431178 - Posts: 613 |
Chart Menu: Goto Date/Time (Chart menu) Menu: Chart - Goto Date Time You can add a keyboard shortcut, or add the command to the control bar as a button. |
[2022-06-03 10:27:26] |
Yes refer to: Chart Menu: Goto Date/Time (Chart menu) For this: how can i put the chart back to today's date?
Use this menu command:Chart Menu: Goto End of Chart (Chart menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
