Date/Time: Mon, 21 Sep 2026 11:26:29 +0000
Can't connect
View Count: 1060
| [2022-05-22 23:03:03] |
| User493842 - Posts: 24 |
Hi Sierra chart support, I paid for my new subscription for the next 3 months but Sierra charts won't connect. Nothing else has changed and other platforms are receiving data so I know it is Sierra charts. Please would you enable my connection please. Thanks |
| [2022-05-22 23:08:50] |
Restart Sierra Chart and let us know if you can connect now.
| [2022-05-23 03:22:39] |
Thanks I have restarted my Sierra chart and had no bars (version 2394)!!! I worked out that if I went back to SC version 2390 I would have data. I also note that I am getting a trial of 2394 for 30 days - does this mean that I would need to change the data feed to Denali?
| [2022-05-23 11:10:11] |
2394 requires the Denali Data Feed for CME and EUREX data: https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2394 You will need to change to service package 10 or 11: Service Package Changes | Discontinued External Services | Reducing Overall Costs Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-05-23 14:39:52] |
Oh wow really? Ok so big problem, I was gonna to change to Denali when AMP allowed Teton but alas no - do you know when they will? I keep asking them but they don't really give me any clues. Thanks
| [2022-05-23 16:37:02] |
| John - SC Support - Posts: 47939 |
We have no special insight as to when they might start using our Teton Order Routing system. It is wholly with them to decide.
| [2022-05-26 02:39:42] |
We would expect AMP to be offering Teton in about 1 to 2 months.
