Date/Time: Wed, 12 Mar 2025 17:11:08 +0000
Time Frame issue
View Count: 519
[2022-05-22 18:48:28] |
Arty - Posts: 1 |
Hello, Ran a update and now my time frames are incorrect. Whenever I choose a time frame the frames at the bottom are incorrect. Ex if I choose 30 mins the increments are in 15. No sure what is going on. Posted a photo. Appreciate any help! |
Attachment Deleted. ![]() |
[2022-05-22 23:07:52] |
Refer to: Chart Session Times: Bar Starting Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
