Date/Time: Wed, 12 Mar 2025 16:48:48 +0000
Back referencing subgraph values at time of entry
View Count: 489
[2022-05-22 14:45:55] |
oliebol03 - Posts: 4 |
I couldn't find anything online about this so I'm not sure if something like this is even supported. I'd like to have a way to go back and see the value of a subgraph right at the time of an entry was made. For example let's say on a day I made 20 trades then after that day I'd like to see the value of delta exactly at the times I entered (so not the delta on close but intrabar delta at the time). I could obviously just load up a low tf chart like a 1 sec chart and reference back to entries but I'd like to know if there is a more organized way of doing this. Maybe in a table form or an extra column in the trade activity log with a filter for the subgraphs you want to see? Anyways, thanks in advance! |
[2022-05-22 15:36:32] |
You need to do a chart replay, to see the intra-bar values: Replaying Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-05-22 17:00:36] |
Yes that's the way I've been doing it so far. Just wondered for journaling if there is a way to have it auto record the values like a snapshot on entry or something like that. But based on your reply I think that such a feature isn't available. |
[2022-05-23 12:45:02] |
There is no built-in way to automatically record intra-bar values but certainly you could develop this capability using ACSIL: Advanced Custom Study Interface and Language (ACSIL) Maybe a good study to look at as a point of reference would be: scsf_WriteBarAndStudyDataToFile Refer to: How to Build an Advanced Custom Study from Source Code Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-05-23 12:46:02
