Date/Time: Tue, 26 Nov 2024 09:36:30 +0000
MA envelope fixed value not working
View Count: 1230
[2014-04-30 11:26:47]
User31737 - Posts: 73
Hi using version 1124 and the MAEnv study is only using the % offset. Not using the fixed value offset
[2014-04-30 19:13:02]
Update to the latest release of Sierra Chart. This problem is now solved.
Here are the instructions to update:
https://www.sierrachart.com/index.php?l=doc/download.php#FastUpdate
