Date/Time: Wed, 16 Sep 2026 00:16:32 +0000
Information displayed above/below the numbers bars
View Count: 2089
| [2022-05-20 16:32:28] |
| Radu Sirbu - Posts: 40 |
Hi guys, I looked through the settings in the Numbers Bars study to see how I could add some information above / below the bars. What I would like to display above or below the bars is the information about delta, colored according to its value. If the delta is positive, it should be displayed above the green bar, and if it is negative, it should be displayed below. Also, I would like to have the option to display according to the value filter, which is only if the delta is greater than a certain value. Is there such feature in any study? Thanks, |
| [2022-05-20 17:05:59] |
| User907968 - Posts: 883 |
Bar Delta Below Bar
| [2022-05-20 17:47:17] |
| John - SC Support - Posts: 47903 |
The above-mentioned study will give you the beginnings. But to do everything you want, you will want to use two copies of the Color Bar Based On Alert Condition in combination with either the above study, or whatever other study you can get the Delta from. You would then use set the Color Bar Based on Alert Condition based on your Delta study and set the Draw Style to either Value on High or Value on Low depending on where you want the data, and set your Alert condition for what you want. Refer to the general information for the Color Bar Based On Alert Condition, but refer to this section in particular: Color Bar Based on Alert Condition: Drawing Arrows/Text or Other Styles at the High or Low of Bars For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-05-20 19:53:02] |
Thanks you John and User907968! I used both information to set on my chart what I was looking for. |
