Date/Time: Wed, 12 Mar 2025 16:18:41 +0000
Chart customization and plan
View Count: 656
[2022-05-20 05:40:43] |
cruxstock - Posts: 6 |
im looking to purchase the plan so I can see real time data for crude oil gold nasdaq etc.. also if I can get some quick help on how to customize my charts to have these exact same indicators and everything else I’ll really appreciate it or the name of indicators and how to add them to the chart and customize everything.
![]() Attachment Deleted. |
[2022-05-20 08:35:42] |
What futures trading/brokerage service do you use? For the reason why we ask this question, refer to: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges (Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-05-20 14:21:57] |
John - SC Support - Posts: 38612 |
For help setting up your charts, we recommend contacting Diana Pena. She is an independent company that helps people with Sierra Chart. You can contact her here: https://bio.link/dianapena For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
