Date/Time: Wed, 12 Mar 2025 16:21:52 +0000
Question
View Count: 450
[2022-05-20 04:16:44] |
bullhaktrades27 - Posts: 4 |
Is it true that the Services with Sierra Chart and Denali 11 will always be delayed by 10minutes unless I my broker is linked to Sierra Charts CQG Routing. And if that is the case what do I have to do to connect my broker (Tradeovate) to Sierra Charts? Thank you
[2022-05-20 14:12:32] |
John - SC Support - Posts: 38612 |
Not exactly. The issue is just with the CME Group data. The CME Group requires that you have a live, funded, futures trading account to which you can connect your Sierra Chart software, in order to get the data at the non-professional rate. Otherwise, you can pay the Professional rates for the data. Refer to the information here: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges And if that is the case what do I have to do to connect my broker (Tradeovate) to Sierra Charts?
If your Tradeovate account is using CQG for order routing, then you just need to follow these instructions to connect your Sierra Chart to your CQG account: CQG Trading Platform Service: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-05-21 09:46:31] |
Also refer to this thread: Move from Tradeovate/CQG to Teton and Save and Get Better Quality Service! Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
