Date/Time: Tue, 26 Nov 2024 09:43:40 +0000
Sierra Data
View Count: 1079
[2014-04-30 03:04:38] |
Discount - Posts: 73 |
I subscribe to Sierra Data. What do I need to do to get the VIX for the S&P 500?
[2014-05-01 08:48:50] |
You need to activate the CBOE Indices exchange.
[2014-05-01 11:38:19] |
How much a month is that?
[2014-05-01 11:38:40] |
As in US Dollars?
[2014-05-01 18:38:46] |
Refer to this page: https://www.sierrachart.com/usercp.php?page=SC_RealTime_DataFeed_SetExchanges Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-05-01 18:46:37] |
Will the CBOE Index's get me the Transports as well?
[2014-05-01 19:28:14] |
Not the Dow Transportation index.
