Date/Time: Tue, 18 Mar 2025 05:03:26 +0000
FTX Crypto DOM
View Count: 1612
[2022-05-19 11:24:17] |
Nkrastins - Posts: 35 |
Hello, first of all thank you for adding FTX exchange, does it support live trading as well? Can't find any official notification document. Second, is there a way to somehow round down the decimals in bid/ask column? Thanks |
[2022-05-19 15:23:29] |
John - SC Support - Posts: 38735 |
No, we do not have trading to FTX, just the data. is there a way to somehow round down the decimals in bid/ask column?
Chart Settings: Price Display Format (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-05-19 19:28:21] |
That display format will not affect the quantity numbers. We need to implement a new setting for that.
[2022-08-29 21:50:20] |
pearlus - Posts: 3 |
You can do it now... Chart Settings -> Market Depth -> Number of Decimal Places for Market Depth Quantities |
[2022-09-22 06:53:30] |
hello, now I have this issue. Chart doesn't download full data. Tried to restart, changed data socket to SC service. Any idea how to solve it? Thanks |
[2022-09-22 07:09:31] |
I think that I am doing something off, because bars seem to appear normal when US cash session starts. |
[2022-09-22 14:54:12] |
Make sure you do not have the fill space locked and that you are not at the end of the chart. Refer to the following: Chart Settings: Lock Fill Space (Chart >> Chart Settings >> Display >> Chart Display Items menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
