Date/Time: Fri, 22 Nov 2024 07:04:09 +0000
Version 967 "Show Menu"
View Count: 2731
[2013-04-26 17:34:09] |
GaryD - Posts: 61 |
I upgraded to version 967 recently, and ever since I did the option to not show the menu no longer works. The box under the heading "Chart" will check and uncheck, but nothing happens. Advice?
[2013-04-26 20:10:32] |
This is not supported until further notice.
[2013-04-27 00:15:54] |
joshtrader - Posts: 488 |
I would like to ask you to please consider adding this back in. I am using 963 and it works great--why not at least give the user the opportunity to use it; if it causes problems, then each individual user can disable it. Do you know how many times per day SC users are clicking the region data line to show/hide studies, etc.? When auto-hide is on (which is a must for many of us at this point, due to the screen space it saves), we can't reliably click on the region data line.
[2013-04-29 01:11:21] |
normal guy - Posts: 16 |
+1
[2013-04-29 09:33:52] |
N2S - Posts: 15 |
+1
[2013-05-07 09:46:11] |
We will have a look at this again in the next few days. There were too many technical complications relating to this. And it was getting difficult for us. But we should be able to bring back this functionality. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-05-08 13:39:40] |
User30668 - Posts: 108 |
+1
