Date/Time: Wed, 12 Mar 2025 16:48:13 +0000
Numbers bar displaying a bunch of (mostly) zeros
View Count: 436
[2022-05-18 22:24:54] |
User789676 - Posts: 6 |
How do I see number of filled orders in numbers bar? Showing almost entirely all zeros (see attached). In replay mode showing *all* zeros. Here is the subscription I have: 12 - Advanced MBO + Denali Data Feed - Active until: 2022-05-30 23:59:59 UTC Please help! Thanks, Caleb |
Attachment Deleted. ![]() |
[2022-05-18 22:59:36] |
You also need to complete the exchange agreements and activate the exchanges that you require. This is done from here: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation#DenaliCME After all of that is done and in effect, you need to re-download the data: Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-05-18 23:01:19
