Date/Time: Wed, 12 Mar 2025 16:39:58 +0000
font size too small to see
View Count: 571
[2022-05-18 18:09:49] |
User977139 - Posts: 2 |
I followed the instructions provided in our previous communications by enlarging the font size however the font was not changed as you can see in the screen captures |
[2022-05-19 00:24:44] |
We will work on step-by-step documentation for what to do in this case.
[2022-05-20 10:10:35] |
Here is the documentation: Graphics Settings: Adjusting Graphics Settings and Fonts for High DPI Displays Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
