Date/Time: Wed, 12 Mar 2025 16:18:08 +0000
Historical Data Not Being Loaded for MCLN22
View Count: 406
[2022-05-18 17:54:48] |
sau1234 - Posts: 8 |
Hi, Historical data is not being loaded properly for MCLN22. Please see the attached screenshot and settings. I am on Denali data feed. Please advise. Thank you. Date Time Of Last Edit: 2022-05-18 17:55:42
[2022-05-18 22:33:26] |
Sierra_Chart Engineering - Posts: 18750 |
MCL is a new contract. There will not be much historical data available for it. Less than six months. So reduce the number of days loaded in the chart to just three or four months at this time. Use the Days to Load setting. Set that to 90.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-05-18 22:33:43
