Date/Time: Wed, 12 Mar 2025 16:59:50 +0000
Volume Profile "Right Align Volume Bars" is set to "Yes" and cannot be changed
View Count: 419
[2022-05-18 10:00:54]
User396 - Posts: 55
I cannot change this settings "Right Align Volume Bars" to "No". Once I select "No", it goes back to "Yes".
Which condition would prevent this setting to be "No" or what am I doing wrong?
thank you,
b
[2022-05-18 14:41:54]
John - SC Support - Posts: 38612
The one time that this would occur is when you are putting the VbP onto a chart with a TPO profile on it. In this case you can not switch the Right Align to No.
