Date/Time: Wed, 12 Mar 2025 16:49:18 +0000
Lines drawn from one study can overlay and hide lines drawn by another.
View Count: 424
[2022-05-18 07:37:35] |
DF86 - Posts: 14 |
Hi, IE "High/low for time period extended" is often drawn over by "Swing high and low ( extension lines). Same thing happens with other line drawing studies. Is there a way to give priority to one study over another so we can change which one gets drawn over? Cheers Date Time Of Last Edit: 2022-05-18 07:40:05
[2022-05-18 14:16:02] |
John - SC Support - Posts: 38612 |
Yes, the order in which the studies are listed on the Studies to Graph is the order in which they are drawn. Refer to the following: Chart Studies: Study Display Order For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
