Date/Time: Wed, 12 Mar 2025 16:21:09 +0000
CQG Web API
View Count: 456
[2022-05-18 05:34:46] |
User565974 - Posts: 32 |
Hi Guys, regarding your new release 2394 - CME Group and EUREX market data is no longer supported through CQG. In my settings I run SC through CQG Web API- version 2391 (with service pack 11 EUREX and CME Denali). If I update to the new version, do I have to change something in the settings, or will CQG Web API still running smooth?? Thanks |
[2022-05-18 06:25:05] |
No settings changes are needed. No user would have to change anything in their Sierra Chart settings.
