Date/Time: Wed, 12 Mar 2025 16:47:52 +0000
Automatik Chartbook Startup at Startup
View Count: 474
[2022-05-17 16:52:14]
User230940 - Posts: 121
I update to the lastet SC Level (2393) some days ago.
I create a new additional Instance and what to startup a Chartbook at SC startup.
I go "Generell Settings/Generell Setting/ [ Generell ] and try to select the Chartbook which should be started automaticaly.
There is a entry call [ select chartbook to open on startup ].
But I can`t select anything. If I click on this topic, nothing will happen.
For my other Instance which was defined some ago SC opens my defined Chartbook at Startup, but I can not see which Chartbook will started.
I thing the menu does not work.
thanks
regards
[2022-05-17 17:35:02]
John - SC Support - Posts: 38612
It sounds like you are doing the correct things.
The first thing we want to make sure of is that you are actually selecting the button that is labeled [Select Chartbook to Open on Startup]. You need to actually click on that text that has that statement. Refer to the instructions for this type of element here:
Settings Windows Interface: Button (Working with Sierra Chart Windows >> Selection Specific Options)
When you select the button you should get a window that looks like the one in the attached file name ChartbooksToOpenOnStartup. If you are not getting this window, then select Windows >> Reset Windows. Then select the button again and the window should show up properly for you.
If you continue to have issues, let us know.
imageChartbooksToOpenOnStartup.png / V - Attached On 2022-05-17 17:34:58 UTC - Size: 4.19 KB - 131 views
[2022-05-18 06:54:56]
Yes, thanks.
I was the Refresh Windows
regards
