Date/Time: Wed, 12 Mar 2025 16:19:13 +0000
EUREX - Dax40 Constituencies prices
View Count: 538
[2022-05-17 16:04:00] |
schopp - Posts: 3 |
hi With the current EUREX data feed that I have enrolled for, I was in an assumption that I would be able to retrieve the prices from the dax40 constituencies. Could you please confirm if there is an additional package/service I need to opt for the live prices on these constituencies of Dax? Date Time Of Last Edit: 2022-05-20 13:13:30
[2022-05-17 16:52:07] |
John - SC Support - Posts: 38612 |
We do not know why you would assume that you would have visibility to the constituent companies that make up the DAX. Those companies' stocks are traded on the Frankfurt Stock Exchange, as opposed to the EUREX where the DAX is traded. We do not have data for the Frankfurt Stock Exchange. You could check with IQ Feed to see if they have the data available and get it from them. Refer to the information here: DTN IQ Feed Data Service If you can use IQ Feed, then you would probably want a second Sierra Chart for the IQ Feed while your other one connects to your trading account. Refer to the following for how to install another Sierra Chart: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
