Date/Time: Wed, 12 Mar 2025 12:27:27 +0000
Good afternoon!
View Count: 381
[2022-05-16 16:15:27] |
User413489 - Posts: 21 |
Good afternoon! Can you tell me how to make a cross - zero chart with equal cells (as in the notebook in a box as an example)? And this question if it is possible to create a grid for this chart so that each cross or zero was placed in its cell - as if it were a notebook in a tangle))
[2022-05-16 18:09:10] |
John - SC Support - Posts: 38598 |
It sounds like you want a Point and Figure chart. Refer to the information here: Chart Settings: Point and Figure Bar (Intraday Charts) Note that you will want to set both the Bar Period Type and the Graph Draw Type to Point and Figure as noted in the documentation linked above. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
