Date/Time: Wed, 12 Mar 2025 16:55:31 +0000
OpenGL Question
View Count: 1082
[2022-05-15 22:57:56] |
jakeybleez - Posts: 56 |
hello, i just recently found out Sierra chart doesnt use your graphics card from the factory. when i turned it on my chartbooks that would run very laggy ran at lightning speed. now that the market is open, every 5 seconds all of my charts will do a flash, then certain areas will highlight with grey boxes. and then it all goes back to normal. and this keeps happening. has this happened before? is there a way i can get this to stop so my GPU is still working with SC |
[2022-05-15 22:58:42] |
It sounds like you are using an AMD graphics adapter and we have heard of this issue in this case: then certain areas will highlight with grey boxes.
We have no control over this. This will not happen with Nvidia. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-05-15 22:59:36
[2022-05-19 18:57:50] |
hello. would an nvidia 3060 work with "open gl"? if so, going to purchase one now. i currently run an AMD 6600 xfx
