Date/Time: Wed, 12 Mar 2025 11:28:16 +0000
real time data
View Count: 435
[2022-05-15 18:44:06]
User991616 - Posts: 5
hello, i have activated and paid for denali, cme group market depth data, i have the [M] enabled next to the symbol, but the header of the window says "5 Min #3 | Delayed" what actions should i take? thank you
[2022-05-15 19:59:22]
First at this time the markets are closed and you will not be getting real-time data at the moment.
However:
The reason you are not getting real-time data from the CME Group of exchanges is that you activated the Non-Professional exchange fees, but you have not verified in the last month that you have a live, funded, futures trading account, which the CME needs in order to allow you data at the lower priced fees.
Refer to the following for instructions on how to connect once a month to your *live funded* trading account to qualify for the lower-priced exchange fees:
If you do not have a funded trading account or one with a supported trading service, then refer to this solution:
Easy Solution to CME Funded Trading Account Requirement
Consider the above solution to avoid this problem in the future.
