Date/Time: Fri, 02 Oct 2026 13:32:25 +0000
Cannot download data - Timeout error connecting to server
View Count: 809
[2022-05-15 11:05:02]
Martin_T - Posts: 1
Hi Support, I'm not able to download data on either of my PC's. Getting the same issues on both. Please advise? Regards, Martin
Software version: 2393 64-bit | 2022-05-15 13:00:46.621
Primary Thread ID: 5624 | 2022-05-15 13:00:46.621
Usage end date: 2022-07-16 | 2022-05-15 13:00:46.621
Enabled for: Advanced Features 2. | 2022-05-15 13:00:46.621
Enabled for: Sierra Chart Historical Data Service. | 2022-05-15 13:00:46.621
Enabled for: Delayed Denali Exchange Data Feed. | 2022-05-15 13:00:46.621
Allow Support for Sierra Chart Data Feeds is enabled. | 2022-05-15 13:00:46.621
Current selected Data/Trading service: SC Data - All Services | 2022-05-15 13:00:46.621
Custom symbol settings values: disabled | 2022-05-15 13:00:46.621
Chart Update Interval: 500 | 2022-05-15 13:00:46.621
Intraday Data Storage Time Unit: 1 | 2022-05-15 13:00:46.621
Time Zone: +02:00:00 (SAST+02) | 2022-05-15 13:00:46.621
2022-05-15 11:00:46 Local computer time in UTC | 2022-05-15 13:00:46.621
2022-05-15 13:00:46 Local computer time in SC Time Zone | 2022-05-15 13:00:46.621
2022-05-15 10:49:06 Server time in UTC | 2022-05-15 13:00:46.621
Local computer UTC time and Server UTC time difference: 45 seconds. | 2022-05-15 13:00:46.621
Notice: Your computer's clock is off by 45 seconds. For help with this, press the 'Send for Analysis' button. | 2022-05-15 13:00:46.621
Program path: C:\SierraChart\ | 2022-05-15 13:00:46.621
Data Files path: F:\SierraChart\Data\ | 2022-05-15 13:00:46.621
OS Version Number: 6.3 | 2022-05-15 13:00:46.621
Locale Setting: C | 2022-05-15 13:00:46.621
DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2022-05-15 13:00:46.621
Allowed protected custom studies: | 2022-05-15 13:00:46.621
Crash reporter started: true | 2022-05-15 13:00:46.621
DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time or established connection failed because connected host has failed to respond. | 2022-05-15 13:00:55.410 *
DTC Client socket (1) | CloseSocket call. | 2022-05-15 13:00:55.410
DTC Client socket (0) | CloseSocket call. | 2022-05-15 13:00:55.410
SC DTC Data with Market Depth | Disconnected from the server. | 2022-05-15 13:00:55.410
DTC Client socket (1) | Closed. | 2022-05-15 13:00:55.410
SC DTC Data with Market Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2022-05-15 13:00:55.410
SC DTC Data with Market Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2022-05-15 13:00:57.400
DTC Client socket (1) | Creating socket. | 2022-05-15 13:00:57.401
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-05-15 13:00:57.401
DTC Client socket (1) | Connecting to IP: 192.81.56.146. | 2022-05-15 13:00:57.401
Historical Intraday data request for SPX500 matches current download and is queued for download since earlier data is requested. | 2022-05-15 13:00:59.363
Added historical Intraday data request for SPX500 to the queue. | 2022-05-15 13:00:59.363
Intraday data recording state for symbol SPX500 is set to download 'Pending'. | 2022-05-15 13:00:59.363
Triggering next historical data download in queue. | 2022-05-15 13:00:59.363
HD Request # 4 | Downloading Intraday chart data for SPX500 to the file SPX500.scid. Service: fxcm | 2022-05-15 13:01:05.623
HD Request # 4 | Download start date-time: 2021-11-10 13:01:05.000000. File last date-time: 2019-03-07 19:58:43.000000 | 2022-05-15 13:01:05.624
HD Request # 4 | Using server: ds4.sierracharts.com port 10149 | 2022-05-15 13:01:05.624
Socket (3) | Creating socket. | 2022-05-15 13:01:05.624
Socket (3) | New receive buffer size: 5242880 | 2022-05-15 13:01:05.624
Socket (3) | Connecting to IP: 192.81.56.146. | 2022-05-15 13:01:05.624
DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time or established connection failed because connected host has failed to respond. | 2022-05-15 13:01:18.424 *
DTC Client socket (1) | CloseSocket call. | 2022-05-15 13:01:18.424
DTC Client socket (0) | CloseSocket call. | 2022-05-15 13:01:18.425
SC DTC Data with Market Depth | Disconnected from the server. | 2022-05-15 13:01:18.425
SC DTC Data with Market Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2022-05-15 13:01:18.425
DTC Client socket (1) | Closed. | 2022-05-15 13:01:18.425
SC DTC Data with Market Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2022-05-15 13:01:20.440
DTC Client socket (1) | Creating socket. | 2022-05-15 13:01:20.441
DTC Client socket (1) | New receive buffer size: 5242880 | 2022-05-15 13:01:20.441
DTC Client socket (1) | Connecting to IP: 204.15.197.14. | 2022-05-15 13:01:20.441
SC DTC Data with Market Depth | Network connection to server complete. | 2022-05-15 13:01:20.711
SC DTC Data with Market Depth | Starting socket receive thread. | 2022-05-15 13:01:20.711
SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2022-05-15 13:01:20.711
SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2022-05-15 13:01:20.997
SC DTC Data with Market Depth | Sending logon request message. | 2022-05-15 13:01:20.997
SC DTC Data with Market Depth | Received logon response. | 2022-05-15 13:01:21.901
SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2022-05-15 13:01:21.901
SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2022-05-15 13:01:21.901
SC DTC Data with Market Depth | Successfully connected. | 2022-05-15 13:01:21.901
SC DTC Data with Market Depth | Trading is not supported. | 2022-05-15 13:01:21.901
SC DTC Data with Market Depth | Restarting real-time data updates for symbol: SPX500 | 2022-05-15 13:01:21.901
SC DTC Data with Market Depth | Received security definition for symbol SPX500 | 2022-05-15 13:01:22.276
Socket (3) | CloseSocket call. | 2022-05-15 13:01:25.628
Socket (3) | Closed. | 2022-05-15 13:01:25.628
HD Request # 4 | Error downloading historical Intraday data for SPX500. Timeout error connecting to server. | 2022-05-15 13:01:25.628
Historical Intraday data request for SPX500 is discarded because a matching download is already pending and the new one is not for earlier data. | 2022-05-15 13:01:25.628
Historical data download thread signaled to stop. | 2022-05-15 13:01:25.628
HD Request # 4 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for SPX500 | 2022-05-15 13:01:25.628
HD Request # 4 | Add time&sales data | Remembered last file record date-time: 2019-03-07 17:58:43.000000 | 2022-05-15 13:01:25.629
HD Request # 4 | Completion time: 20s. | 2022-05-15 13:01:25.629
HD Request # 4 | Intraday data download complete for SPX500. Unique request ID: 0 | 2022-05-15 13:01:25.629
Historical data download ID 0 not found when removing ID from outstanding request set. | 2022-05-15 13:01:25.629
Real-time Intraday chart data file updates started for SPX500 | 2022-05-15 13:01:25.629
Opened cached Intraday file: F:\SierraChart\Data\SPX500.scid. Thread ID: 5624 | 2022-05-15 13:01:25.630
Intraday chart data file opened for SPX500 | 2022-05-15 13:01:25.630
HD Request # 4 | Enabling Intraday chart updating for symbol. | 2022-05-15 13:01:25.630
Triggering next historical data download in queue. | 2022-05-15 13:01:25.630
HD Request # 5 | Downloading Intraday chart data for SPX500 to the file SPX500.scid. Service: fxcm | 2022-05-15 13:01:25.630
HD Request # 5 | Download start date-time: 2019-03-07 18:57:00.000000. File last date-time: 2019-03-07 19:58:43.000000 | 2022-05-15 13:01:25.630
HD Request # 5 | Disabling Intraday chart updating for symbol. | 2022-05-15 13:01:25.630
HD Request # 5 | Using server: ds12.sierracharts.com port 10150 | 2022-05-15 13:01:25.631
Socket (3) | Creating socket. | 2022-05-15 13:01:25.631
Socket (3) | New receive buffer size: 5242880 | 2022-05-15 13:01:25.631
Socket (3) | Connecting to IP: 204.15.197.14. | 2022-05-15 13:01:25.631
Socket (3) | CloseSocket call. | 2022-05-15 13:01:45.617
HD Request # 5 | Error downloading historical Intraday data for SPX500. Timeout error connecting to server. | 2022-05-15 13:01:45.617
Added historical Intraday data request for SPX500 to the queue. | 2022-05-15 13:01:45.617
Socket (3) | Closed. | 2022-05-15 13:01:45.617
Triggering next historical data download in queue. | 2022-05-15 13:01:45.617
Historical data download thread signaled to stop. | 2022-05-15 13:01:45.617
HD Request # 5 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for SPX500 | 2022-05-15 13:01:45.617
HD Request # 5 | Completion time: 20s. | 2022-05-15 13:01:45.617
HD Request # 6 | Downloading Intraday chart data for SPX500 to the file SPX500.scid. Service: fxcm | 2022-05-15 13:01:45.618
HD Request # 6 | Download start date-time: 2019-03-07 18:57:00.000000. File last date-time: 2019-03-07 19:58:43.000000 | 2022-05-15 13:01:45.618
HD Request # 6 | Disabling Intraday chart updating for symbol. | 2022-05-15 13:01:45.618
HD Request # 6 | Using server: ds4.sierracharts.com port 10149 | 2022-05-15 13:01:45.618
Socket (3) | Creating socket. | 2022-05-15 13:01:45.618
Socket (3) | New receive buffer size: 5242880 | 2022-05-15 13:01:45.619
Socket (3) | Connecting to IP: 192.81.56.146. | 2022-05-15 13:01:45.619
Socket (3) | CloseSocket call. | 2022-05-15 13:02:05.618
HD Request # 6 | Error downloading historical Intraday data for SPX500. Timeout error connecting to server. | 2022-05-15 13:02:05.618
Added historical Intraday data request for SPX500 to the queue. | 2022-05-15 13:02:05.618
Triggering next historical data download in queue. | 2022-05-15 13:02:05.618
Socket (3) | Closed. | 2022-05-15 13:02:05.618
Historical data download thread signaled to stop. | 2022-05-15 13:02:05.618
HD Request # 6 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for SPX500 | 2022-05-15 13:02:05.618
HD Request # 6 | Completion time: 20s. | 2022-05-15 13:02:05.619
HD Request # 7 | Downloading Intraday chart data for SPX500 to the file SPX500.scid. Service: fxcm | 2022-05-15 13:02:05.619
HD Request # 7 | Download start date-time: 2019-03-07 18:57:00.000000. File last date-time: 2019-03-07 19:58:43.000000 | 2022-05-15 13:02:05.619
HD Request # 7 | Disabling Intraday chart updating for symbol. | 2022-05-15 13:02:05.619
HD Request # 7 | Using server: ds12.sierracharts.com port 10150 | 2022-05-15 13:02:05.619
Socket (3) | Creating socket. | 2022-05-15 13:02:05.619
Socket (3) | New receive buffer size: 5242880 | 2022-05-15 13:02:05.620
Socket (3) | Connecting to IP: 204.15.197.14. | 2022-05-15 13:02:05.620
Socket (3) | CloseSocket call. | 2022-05-15 13:02:25.621
Socket (3) | Closed. | 2022-05-15 13:02:25.621
HD Request # 7 | Error downloading historical Intraday data for SPX500. Timeout error connecting to server. | 2022-05-15 13:02:25.621
Historical data download thread signaled to stop. | 2022-05-15 13:02:25.622
HD Request # 7 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for SPX500 | 2022-05-15 13:02:25.622
HD Request # 7 | Add time&sales data | Remembered last file record date-time: 2019-03-07 17:58:43.000000 | 2022-05-15 13:02:25.622
HD Request # 7 | Completion time: 20s. | 2022-05-15 13:02:25.623
HD Request # 7 | Intraday data download complete for SPX500. Unique request ID: 3 | 2022-05-15 13:02:25.623
Removing historical data download ID 3. | 2022-05-15 13:02:25.623
Real-time Intraday chart data file updates started for SPX500 | 2022-05-15 13:02:25.623
Opened cached Intraday file: F:\SierraChart\Data\SPX500.scid. Thread ID: 5624 | 2022-05-15 13:02:25.623
Intraday chart data file opened for SPX500 | 2022-05-15 13:02:25.623
HD Request # 7 | Enabling Intraday chart updating for symbol. | 2022-05-15 13:02:25.623
Triggering next historical data download in queue. | 2022-05-15 13:02:25.623
No download requests in the queue to start downloads for. | 2022-05-15 13:02:25.623
DTC Client socket (2) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-05-15 13:02:45.107
DTC Client socket (2) | Closed. | 2022-05-15 13:02:45.107
SPX500[M] 60 Min #1 | Reloading chart. | 2022-05-15 13:03:01.788
DTC Client socket (2) | Deleting network socket now after delay. | 2022-05-15 13:03:15.115
