Date/Time: Tue, 26 Nov 2024 09:44:08 +0000
Chart data error?
View Count: 969
[2014-04-29 13:10:32] |
Greentea - Posts: 26 |
Using SC datafeed but CLM4 has time chart bar that closes at 1.01 price. This causes whole entire chart to compress and cannot be used to trade. Date Time Of Last Edit: 2014-04-29 16:35:46
[2014-04-29 16:36:16] |
Refer to help topic 2 here: Http://www.sierrachart.com/index.php?l=doc/helpdetails2.html If you need further help, post an image of the chart, by following these instructions: https://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
