Date/Time: Wed, 12 Mar 2025 11:59:00 +0000
[Programming Help] - I route my orders through CQG, and I want to verify that I am receiving the right data
View Count: 545
[2022-05-13 22:16:42] |
User990269 - Posts: 3 |
I use tradovate and route my orders through cqg. The top of my chart says cqg web api. I want to ensure that I am receiving the Denali advanced mbo feed. Can you verify that I am, or give me a way to check? If I am not, how can I enable it?
[2022-05-16 14:42:02] |
John - SC Support - Posts: 38598 |
You are properly setup with Package 12 and the Denali Exchange Data Feed with the Full CME Group with Market Depth exchange active. So you should be getting the data from us along with the MBO information. If you have not already done so, then go through the following setup for the MBO information: Market By Order Data: Step-by-Step Instructions If you go through the above and have the Market Orders columns and are getting the MBO data, then you are getting the data from us. We do not have support for MBO information with any outside vendor. You can also look for the [M] marker after the symbol, which also denotes that the data is from us. Refer to the information here: Chart Data and Chart Data Files: The Meaning of the [M] Designation after a Symbol For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
