Date/Time: Fri, 07 Feb 2025 14:46:39 +0000
Alert conditions on TPO Profile chart
View Count: 459
[2022-05-13 16:10:51]
User143517 - Posts: 68
Hi there,
Is it possible to generate an alert condition on a TPO profile chart using a similar approach that is used in the color bar based on alert condition study? i.e.: Color a letter/block if price moves "X" ticks from the lowest/highest letter/block?
If not, could I accomplish this using another study or alert?
Thank you.
[2022-05-13 16:39:51]
John - SC Support - Posts: 37808
There is not a way to externally color the letters/blocks of a TPO chart. The only coloring options are what are part of the study itself.
