Date/Time: Wed, 12 Mar 2025 11:43:58 +0000
The difference between Gain Capital and Sierra chart
View Count: 504
[2022-05-13 05:42:36] |
User290950 - Posts: 13 |
Hello I got a demo account from Gain Capital and when I compare Delta and footprint between Sierra chart and Gain Capital, I see Huge difference, Can you explain why? Regards |
[2022-05-13 06:06:38] |
For accurate Numbers Bars do the following: Set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here to do this: Tick by Tick Data Configuration The data is going to be 100% accurate when using SC Data-All Services. We cannot make any assurances with Numbers Bars when using Gain Capital data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-05-13 06:07:05
