Date/Time: Tue, 26 Nov 2024 09:53:18 +0000
S/R level import from spreadsheet to chart
View Count: 1447
[2014-04-29 09:02:00] |
User81127 - Posts: 15 |
Hi, is there any tool how to import my Support/Resistance levels from .xls file into my charts fast and easily please? Thank you. Jiri |
[2014-04-29 09:06:28] |
This can be done by using the Spreadsheet study: https://www.sierrachart.com/index.php?l=doc/doc_WorksheetStudy.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
