Date/Time: Wed, 12 Mar 2025 11:40:37 +0000
Trading Command / Move Stop X Ticks When Pressed
View Count: 411
[2022-05-12 14:14:11] |
User871209 - Posts: 91 |
Hello, Is there a button that can be assigned to a Control Bar (1-7) that every time it is pressed can move the stop X amount of ticks to protect profit in position? I was not able to see a Trading Command that would be able to do this. Thank you, |
[2022-05-12 15:31:12] |
John - SC Support - Posts: 38598 |
There are some control bar options for moving stops and targets one tick up/down. They are under the section for Trading Commands on the Customize Control Bars >> Control Bar n window. Refer to the following: Control Bar: Customize Control Bars >> Control Bar 1-12 (Global Settings) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
