Date/Time: Wed, 12 Mar 2025 11:53:58 +0000
How to reduce height of Numbers bars Panel ?
View Count: 508
[2022-05-12 13:31:15] |
Mustang77 - Posts: 122 |
Hi the question is about the study "numbers bars calculated value". How can i make the rows smaller? right now they take too much space from the chart. See photo attached Thanks |
![]() Attachment Deleted. |
[2022-05-12 15:22:24] |
John - SC Support - Posts: 38598 |
You need to adjust the height of the region. Refer to the following: Working With Charts: Chart Window and Regions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-05-15 12:06:57] |
Hi John Thank you for your help |
