Date/Time: Wed, 12 Mar 2025 11:35:23 +0000
heures de session
View Count: 615
[2022-05-12 10:49:53] |
User220939 - Posts: 36 |
Bonjour, Quand je copie un chart dans un même chartbook il y a les mêmes heures de session pour tous les chart. Si je veux changer les horaires pour un seul chart ça me les change pour tous. est il possible d'avoir des horaires différents pour plusieurs chart? Par exemple je voudrais un chart dax de 2h15 a 23h30, et un autre chart de 9h00 à 17h35 dans le même chartbook. Je n'arrive pas à trouver comment faire. Merci Cdlt |
[2022-05-12 14:57:07] |
John - SC Support - Posts: 38598 |
From Google Translate: When I copy a chart into the same chartbook, there are the same session times for all the charts.
If I want to change the schedules for a single chart, it changes them for all of them. is it possible to have different schedules for several charts? For example I would like a dax chart from 2:15 a.m. to 11:30 p.m., and another chart from 9:00 a.m. to 5:35 p.m. in the same chartbook. I can't find how to do it. It sounds like you have Chart Linking setup on the one chart that you are duplicating, and it is set to control the Session Times (at least). When you duplicate that chart, then the chart linking copies as well and both charts are then linked, so a change to one will affect the other for the items that are linked (Session Times, in this case). Refer to the following: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#LinkNumber For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
