Date/Time: Fri, 14 Mar 2025 14:02:57 +0000
Missing Custom Intraday Session End Time
View Count: 545
[2022-05-12 02:55:57] |
User762422 - Posts: 7 |
Hi, The Custom Intraday Session End Time is missing on my TPO options. I only see Custom Intraday Session StartTime |
![]() Attachment Deleted. |
[2022-05-12 03:17:06] |
File attached
[2022-05-12 17:45:22] |
John - SC Support - Posts: 38653 |
This has changed. Rather than entering the End Time, you enter what would be the Start of the next session. Then the end of the previous session is 1 microsecond before that start time. If you are just using one intraday session, then enter the start time in 1 and the end time in the 2nd start time, but as the even time unit. For instance, if you are wanting a session from 08:00 to 09:59:59, then you would enter 08:00 for the first Start Time and 10:00 for the second start time.
[2022-06-23 08:00:20] |
This has changed again. There is now an End Time for TPO Chart Custom Intraday Sessions. Update to the current version: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-06-24 17:14:12] |
Rathinp - Posts: 3 |
Hi, Thank you for adding the option. Is it possible to also make it effective - at the moment regardless of the end time the setting defaults to -1 second of the beginning of the following session? EG. If i want to have 3 sessions which start and end at different times within a 24 hour period, is currently not possible, 12:00 - 18:00 19:00 - 00:00 1:00 - 11:59:59 This would currently not be possible. Cheers, R |
[2022-06-24 17:48:08] |
That was part of the problem and why it had to change. You can not do what you are wanting to do with those inputs. Refer to the information at the following link: Time Price Opportunity (TPO) Profile Charts: Custom Intraday Session# (1-5) End Time For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
