Date/Time: Wed, 12 Mar 2025 11:46:46 +0000
Spreadsheet alert to draw arrows
View Count: 590
[2022-05-11 15:02:30]
User14953 - Posts: 243
Can a spreadsheet alert draw arrows on a chart when triggered but never post anything to the Alert Manager?
[2022-05-11 17:16:14]
John - SC Support - Posts: 38598
There is not a way to not post the information to the Alert Manager.
Another option would be to use the Spreadsheet Study to do this, but you would have to change your condition to return the value where you want the arrow to be located rather than just a True or False. For example, if you are using the Arrow UP, then you might want to have it located at the Low of the bar, therefore your condition would have to return the low of the bar for the result in order for the arrow to be drawn properly.
In the Spreadsheet Alert study, the location of the arrows is pre-defined.
