Date/Time: Wed, 12 Mar 2025 11:53:44 +0000
New AMP NEW SIRRA account
View Count: 517
[2022-05-11 14:57:11]
AC136339 - Posts: 34
Sorry for my english, I help myself with google translate.
Hi, I'm the husband of Eugenia Lazari, my name is Andrea Cuceli and I use Sierra Chart from a lot.
I used it with Transact, some time ago, now I opened an account with AMP and as I also did the procedure with my wife, always AMP account, with CQG, and then Denali Sierra Chart.
But I don't remember how to proceed, for now I have the AMP account activated, now how do I proceed?
Because I remember that you at the time tell me that it was not good to create an account, with you, I directly, but you had to do another procedure..
Can you explain to me step by step how to do it?
Many thanks in advance
[2022-05-11 17:07:16]
John - SC Support - Posts: 38598
Since you have setup an account with AMP using CQG for your Order Routing, you will need to go through the setup instructions at the following link to connect your Sierra Chart to your CQG account:
CQG Trading Platform Service: Setup Instructions
After you finish that setup, you will need to change the symbols in your charts to match what CQG uses. To do this, open your Chartbooks and select Edit >> Translate Symbols to Current Service. Refer to the documentation for this for more information:
Edit Menu: Edit >> Translate Symbols To Current Service
